Thermostat Pro
Trying to get set up a virtual thermostat pro using
Output : On/Off switch - widom wpm1.04S : http://www.widom.it/en/energy-driven-switch
Thermometer : Latest ,(Aeon Labs Multi Sensor 6)
Input : Aeon Labs Multi Sensor 6
No luck so far. I can sometimes turn on the switch if changing the set temperature, but then it turns it self off again after ~30seconds. In the begining(have added/removed the thermostat severeal times) it displayed the aeon temperature correct, but now the thermostat displays 5 degrees instead of the actual 21 degrees reported by the aeon sensor. Any clues?
Can also be a bug. Either way, do a clean run (remove the existing and create a new thermostat pro) at the thermostat pro again but only use the output and the thermometer. Since you don't have a wall thermostat or radiator valve with buttons) that would allow you to manually change the required temperature, you don't use the input. I'm not sure if this can cause any issues, but worth a try.
Also remember that the Aeon sensor (even if installed with calbe) does not report the temperature when included, only when there is a motion (to save battery). You will need to change parameter (not sure the number but it is somewhere at the top section of the configuration), which is responsible for enabling or disabling the temperature and other reporting depending or not depending on the motion sensor. Also need to reduce the temperature threshold (if i remember correct this is parameter 41) to a lover value as default it only reports temperature changes only above 1 or 2 degrees, which is not appropriate for temperature purpose on a thermostat.
If the above is no good, contact support.zipato.com
Got it working. Thanks for input.
