handle two zipatile from one
importhomesas shared this question 9 years ago
I have two zipatile and want to manage them from a single zipatile without having to switch box, put a slave of another and that the devices are managed from both.
How I can make one is a slave to the other?
The only way of managing two zipatiles without changing boxes is to create a cluster. In order to create a cluster you need to have the PRO license with is $99 euro and it is still in beta phase. You need to upgrade your boxes to the latest beta firmware (1.1.23) and open a zipato support ticket so they can move your boxes to the temporary server, then you need to reboot your boxes and create the cluster. This will create a "virtual controller" called cluster which is basically your two boxes interacting from the web. Downsides of this is that if you loose internet connection the devices connected directly to the boxes (Z-wave) will be only controllable from that box, so if you loose internet and one box those devices will be offline to the other controller. Read more here;
https://community.zipato.com/announcement/cluster-option-available-for-testing
thanks
