Zipabox And Somfy Oximo
Firstly sorry for my english, i will do my best.
I have a somfy oximo motor, is it compatible with zipabox?
If yes, what the procedure?
Thank you
email support for an answer. I don't think so, as they only mention Somfy RTS motors.
Anything new? I would like to use Somfy Oximo and not sure if it works. RTS or IO? Anyone knows? Any advice?
Tecnically this is a 433 Mhz device and should be supported by Zipabox with 433 Mhz module but I would ask Zipato directly by opening a ticket as Adrian suggests.
Support is unsure either so the only thing remains is to test it. On Somfy site Oximo also has the added RTS text so now what...
Hello, Somfy RTS is supported and tested, related to Somfy Oximo, it is still not tested.
