Supported panic buttons?
it seems you support Aeon Labs panic button, Benext oanic watch. Do you have a list of other devices that can be added as a "panic" type alarm zone? Can the Fibaro button be used? Philio smart color button? Can you use any wall sender (intended to control lights etc)?
By using rules I guess anything is possible. Any input devise (especially batter operated remote controllers) should do the trick.
But for your predefined alarm functionality you need to select a "sensor". Are the buttons and wall sender mentioned above categorized as "sensors" by Zipato?
