Rule with multiple "OR" operators
Luca shared this question 9 years ago
I'd like to create a rule with multiple "OR" operators.
E.g. at a given time, check every blind sensor status (I have 7 blinds), if one of them is "open" then send a single message.
At this moment, I achieve this result using a single IF for every single blind (see attachment), but I'd like to group all the checking cycle (E.G. IF blind 1 position > 15 OR blind 2 > 10 OR blind 3 > 12 THEN send message "one of your blinds is open")
How can achieve this?
Files: rule.jpg
With nested ORs! Or did I misunderstand your problem?
If it becomes too clumsy because the ORs stretch off the screen on the right, you can do the following:
set variable BlindsOpen = 0
if (blind1 open) or (blind2 open)
set variable BlindsOpen = 1
if (blind3 open) or (blind4 open)
etc
if (BlindsOpen)
SendMessage
Files: ORs.png
Thank you David for your answer...
But I'm missing that point: how can I say "If blind1>0 OR blind2>0 then send message"?
I can use neated ors and add multiple sensors, but £'m not able to add the part ">0"
Sure you can!
Files: ORs2.png
Finally I find the way with nested ors!
Effectively, the rule becomes really too clumsy, so it's way better to use variables.
Thank you for your help!
No problem
David, no wonder why are you a pro user. Again thunbs up.
Although this is a double post, i will not remove it :)
