How to cascade zipabox with zipatile?
YF Chin shared this question 9 years ago
I have a zipatile and a zipabox.
Anyone know how to combine / cascade this 2 controller? So that I can control all devices included in both controller in the zipatile.
You will need to upgrade to pro license both controllers = 2*100 Euro. Then you need to create a cluster and include both controllers into it. https://community.zipato.com/announcement/cluster-option-available-for-testing
Im not aware of any other method although we should be able to control all devices in one controller via the another controller via some IP connection or what but this is unknown if possible.
I have the same constellation. I use the Zipatile as controller and also as android tablet. With the zipato app you can control both controllers. You can switch between them. So far so god, but not perfect.
By box is the main controller with over 100 devices. In the moment I do not want to try cluster. I use on both sides virtual meters. Those virutal meters can receive http commands. With this method I can exchange binary information between both boxes. I.e. if zipabox alarm partitiion is tripped, it sends a command to Zipatile and it plays alarm sirens and Sonos.
This works very fast and reliable.
On the Zipatile in theory runs Imperihome. But without google shop it makes no fun. So for the moment I stick to the solution above.
Thanks guys..
Will try to get it done... Thanks for your helps...
