Neo Coolcam Power Plug
Mathias Solheim shared this question 9 years ago
I bought a Neo Coolcam Power Plug Z-wave from AliExpress.
I got it to connect and manage to turn it on and off, but the consumption or voltage reports is not showing.
I found this online:
https://github.com/OpenZWave/open-zwave/pull/969/files
Is there anyway I can update this to get the consumption to work?
contact support, only they can implement this
Refer the zwave alliance certificate. This way they should provide support without the need to send a physical product
I have the same wallplugs (several) and they work great.
You have to adjust your setting in the Module Manager to get the readings.
First of all select your device in the module manager and open it by clicking on it. Now dig a little deeper until you find your "meters". As you can see below I changed the names of the meters to my own liking.
5970c73f3efebe828ed12260ba428320
Originally they have the names below:
09f2ac6b5191d32ac576b4c7bf27af68
Now open the configuration of each meter (click settings), give it a proper name, set type to "generic meter meter" and select the option to show it as a device. Now save your configuration and adjust the next meter.
Don't forget to synchronize (in fact I had to do this several times) and in the end you get the expected result:
86c645840f1760e8a91f51329af0ddd9
Good luck
I also have these sockets and I have a problem with measuring total consumption. Current power is 800W, curent amps 3,5A, current voltage 250V +/-, but cumulative consumption in the same time interval is only 0,4 kWh, it should be approximately 2 kWh. any ideas please?
7bac678f9a2e4d955c2f91f38c3c145f
8c5d609f88f47fa3821db5fbac24bf06
23180f3653a0697b2e8a635c21f46e59a18e6e30f1582c9cff3b29e70b179775
