Thermostat on main screen Zipatile
Vincenzo Coletta shared this problem 9 years ago
Hi, I've 3 thermostats set on my Zipatile with 3 different thermometers. On the main screen (see attached picture) I just see the last of the 3 temperature (unknown the reason why it is reported as "Thermostat" if it is just the temperature!) but no possibility to change, to choice a different thermometer from the ones available or to click and set anything...
Does it is needed for anything? Assumed the answer is not, how at list select between the available temperature and change description??
Dears...
I just put the question and it immediately shows as "Known". Immediately means less than 1", just the time to refresh the page...
Since this seems quite unlikely that somebody in less than 1" read and marked the message as "known", please do not joke with your customers. This is not fair and not expected from you!
It is not possible to put 3 numbers at the same place. Thermostat on the home page shows the temperature of the internal Zipatile thermostat which you can use or not. At this moment, it is not possible to change the icon on the home page, but we will publish a new design next year where this is going to be possible.
But i had the "main floor" thermostat showing at first? and now I have the "upper floor" one showing? None of those are the zipatile thermostat. Something happend and the "show order" was rearranged?
it is not showing the thermometer of the zipatile but "randomly" any of my 25....
Yes, it happens to mine also. And if you click on the temperature it opens one of the thermostats that is not the main... please fix it.
