Zipatile wifi disconnection/ reconnection
vincenzo esposito shared this problem 9 years ago
Good morining, ihave my zioatile working in Cloudless mode.
is there any way to force Zipatile to re-connect to wifi after a wifi lost connection?
with rules or scenario?
my zipatile if lost its wifi connection is not able to reconnect alone again.
No. No rules will help you. Here is an advice based on experience. Firstly remove cloudless mode. Secondly add another WIFI network that is close to the zipatile and has a good signal strenght (ideally in the same room only couple of metres from ziptile). Based on experience despite you might think the zipatile has great wifi signal, it still might disconnect. Consider also that zipatile is still the most reliable android device in terms of wifi kept on. Any phone I had, disconnects wifi more often than zipatile.
Zipatile WiFi interface should automatically reconnect Zipatile service regardless of status of Cloudless mode. Current issue is under investigation
Hi Tomislav. I remember initially dealing with this. I have provided numerous feedback to the Zipato team and was the first of customers receiving the Android 1.0.3 version to test the WiFi. It is lot more reliable since this firmware update but once in a month it can happen that zipatile disconnects. When it does, the wifi icon on the status bar is completely missing and approx by 10 seconds after the screen is turned on (for example after you touch it) it reconnects. I have tried tasker and other tools at the beginning, but did not help. Anyway 1.0.3 is fairly reliable, however I experience 1x month disconnect of zipatile (for example my morning rule does not execute).
thanks for the answers.
Just for clarification, in my case the problem is due to the switch off of the modem or ADSL signal lost, so far, does not seem to be a problem of Zipatile. I wondering if there is a way to make Zipatile, alone, able to reconnect after returning to wi-fi.
