Get value from device on web server (json)
Magnus Wingqvist shared this question 9 years ago
Can I get a value from a device from a web server? I can get it locally (when I'm logged in), but can't seem to get it when fetching from a web server. I'll guess it's because the web server is "not logged in". Can this be done?
php code:
$json = file_get_contents("https://my.zipato.com/zipato-web/v2/attributes/xxxxxxx-xxxx-xxxx-xxxx-xxxxxxxx/value");
$obj = json_decode($json, true);
$temp= $obj->value;
(this is a temperature device which gives this locally, se below)
"value" : "21.0",
"timestamp" : "2016-12-28T20:53:51Z"
Magnus
You can call the API, after proper authentication.
Browse the API here https://my.zipato.com/zipato-web/api/ (after you've logged in using the same browser to the UI).
Ok. Is there no chance of fetching data from the server-side? I wan't to built my own customized UI for my devices. Is this possible?
