Zipatile GUI Status slow to update if switches manually used
Chris shared this question 9 years ago
I've noticed that if I manually use my light switches at the wall (GE in-wall toggles) that the GUI on the Zipatile takes about 5 minutes to update and register the manual changes. If I use the Zipatile GUI to turn on/off devices it's updated right away.
Thinking this might be an android issue I created a rule that if I turn on/off my dome light switch, a lamp light switch should turn on as well (on another GE in-wall toggle switch). If I use the Zipatile GUI to turn on the dome light, the lamp light turns on at the same time. If I use the wall switch to turn on the dome light, 5 minutes later the lamp will turn on when the GUI is updated.
I have started a network heal to see if that will help, just posting here to see if anyone else has noticed this or has a solution. It may all be 100% my fault too which is why I'm double checking.
