Zipatile - Arm security partition with a touch event, no PIN requested
Luca shared this question 9 years ago
I found this strange behaviour in my Zipatile: if I try to arm a security partition in the device tab, it (correctly) asks for a PIN code.
But... if I set a touch event using rules in the web app (eg. two fingers movement down) to arm the same partition, it doesn't ask me for the PIN code and it arm/disarms the partition with no questions.
Is that normal or is a lack in the security system?
There is also an "QUICK ARM" option within the Alarm settings. This option will allow you to arm from within a RULE, and in this case PIN won't be required for arming partition.
if you have recently disarmed or armed, via pin or swipe as you have it set up, you do not need to use the pin again for a short time. There is a time delay.
Now it's clear, thank you!
