Avoid Zipatile internal camera to take unwanted screenshots
Luca shared this question 9 years ago
is it possible to avoid Zipatile internal camera to take unwanted screenshots?
I found on the archive a lot of daily screenshots that I never took or request.
disable it in the device manager (internal) and/or put some plastic tape on it.
I have the same problem, I open a ticket on this issue.
zipato people is working on it, but up to now nothing, also after a complete wipe of zipatile.
I not understand what is the condition that shot camera.
when, and if, I will have good news I advice you.
Instead where is it possible to disable? can i have more info?
I will also open a ticket. This behaviour deeply concern privacy matters.
I don't want to disable my camera because I don't think this is a reasonable solution, as I use it as a support to intruder alarm actions.
After getting in touch with Zipato support, I learned that the Zipatile takes two screenshoots with the internal camera every time you perform a synchronization. You can' t disable this option at the moment.
I think this is really annoying, and as I told in my previous post, this deeply concerns privacy matters.
Someone could have bad surprises after a sync from remote ;-)
yes, I received the same answer from support, I have checked and seems to be right.
they should solve the problem in the next issue of firmware.. I hope it.
for now I'm obliged to cover the camera, I don't like have snapshots of my family archived on server.
