PAN08 motor controller calibration
How does the PAN08 motor controller calibration detect the end of the movement? I have a water valve that needs up/down outputs to control the valve and it appears that the PAN08 would work for this, but I need to know what it does for calibration. Or perhaps I can not calibrate it? The water valve turns the motor off internally once it reaches the limit, so there is no harm in leaving it fully powered in the up or down position. All I really need is a Z-wave SPDT switch, but I can't find that. The PAN08 looks like it could work if I can understand how calibration works internally and if it is necessary or not.
thanks!
There is a video on youtube zipatotv.
Check out.
Check out.
The video on the motor controller is interesting, but it doesn't tell me how the controller senses the limits, nor does it give me a hint as to whether it would work with the valve or not. Any other thoughts? I think it might work, but I can't be sure without more information. Thanks.
I can imagine that the limits are measured via the power consumption. When it drops again, it means that movement stop. This is only an idea and you would need to test it.
Yes, that is what I would like to know. How does it know there is a stop movement? If it is a decrease in current, then this will work fine for the valve I have. If it is an increase in current (as the motor stalls?) or some other method, then it won't work. It's not easy to buy and install this, so I'd like to get a little more information before I try it. Thanks.
Send an email to support to answer and then share they anser with us.
Dear John,
please check the attached user manual of PAN08 for your reference. You may find the command class to set the position between top and down. For the SPDT switch, please also check the attached user manual of PAN07.
any questions please let me know.
Pero Zovkic
Dear John,
Pero Zovkic
Hello Pero, thank you for responding. I looked at the PAN08 manual, but I can't find how it determines the end of travel. I'm guessing that it might work by detecting current decrease which would be fine for me, but I can't be sure of that with only this manual. Is there any information on this detection?
However, the PAN07 looks better for my use. It is simpler and should work. But how do I buy it? I cannot find it for sale anywhere and I don't see it on your web site. I am in the USA. Also, can it be used with a small motor? It says it is rated for resistive loads - I don't see anything on motor loads.
thanks
thanks
