Fibaro dimmer going to value 65% by self if i put it on higher than 80 %?
everything is going good just this problem when i put the value of Fibaro dimmer 2 on higher than 80 % it's turn off by self and back on to round 65%.
anyone have any idea?
i use normal lamp with 28 W.
The dimmer 2 has so many parameters that it is way too much (starts to be like qubino). My best bet is to try to remove and readd the device. Have you tried calibration? Do you have Bypass attached to is?
