Replace failed nodes tutorial
Vincenzo Coletta shared this problem 9 years ago
Hi, I received an errore message after trying to replace a failed node. Now it does not works but it's listed into the z-wave devices... Is there any place in this site or any documentation or tutorial to understand how use the replace function step by step?
It is definitely working. The failed device should be replaced with the same type i guess so the config will be the same.
Many tks Attila! The new one must be included before starting the replacement procedure or it will be asked to include during the procedure? And the failed one can be disconnected before starting the procedure?
