Is there an EnOcean module for Zipatile?
Ljuca Mario shared this question 9 years ago
For Zipabox there exists an EnOcean extension module. Does something similar exist for theZipatile or is the only possible solution to buy a Zipabox with the EnOcean module and get it to work with Zipatile in a cluster?
Yes in a Cluster it will work.
Is there no other possibility to run Zipatile with EnOcean?
no the zipatile does not contain an enocean module. But you can use a Zipatile as a controller for the zipabox without needing a cluster licence. Just set the zipabox as the controller in the app, all widgets work, new touch manager allows for devices to be controlled via touch buttons and works on local connection too then. But if the zipatile resets it will most likely go back to the zipatile controller, then you need to change back to zipabox in the app again. cluster will stay in the cluster.
