How to use warm white within Domoticz interface with RGBW bulb
Jorn Meijers shared this question 9 years ago
Since a few days I have Domoticz up and running on a Windows machine with 2 RGBW bulbs. Within Domoticz I can Dim the bulb and set the RGB color. The only question for me is how can I tell the bulb to use the warm white led?
I am not familiar with Domoticz, but with the Zipabox you can set the desired color for a RGBW bulb (for instance in a rule) with a colour code, which is in fact a hexadecimal code. If you choose WHITE it always fills in "ffffff", which is in fact a very cold white. Doesn't matter if you select warm or cold white, it always fills In "ffffff". I suppose this is not correct.
You can calculate or choose your own desired colour here: http://www.rapidtables.com/web/color/RGB_Color.htm
With the Zipabox you can select an action block with the action "setrgbw". Fill in the correct hexadecimal code without the "#", and you are set.
I hope this also helps you with Domoticsz.
Good luck
