Problem with DOOR-WINDOW VS-ZD2102.EU
Marco shared this problem 9 years ago
I have 2 Door / Window Sensor modules VS-ZD2102.EU.
External contact does not work. I do not have the menu "External Contact value" in the Domoticz menu.
Is there a trick to make it work?
Thank you in advance for your response.
It is configuration option 1. But I cannot see what values are to be insterted and the byte size. You might need to exclude and include the sensor with the external sensor attached to it.
4960cd6e5efc43a2f1410748206bca30
"exclude and include the sensor with the external sensor attached to it"
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Tableau Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Thank you
for your reply, but I have already tried
Thank you for your reply, but I have already tried
