Clas Ohlson's "Zipato Zipabox Duo"
Oheimala shared this question 9 years ago
Hi, I tried to ask Clas Ohlson support about their "Zipato Zipabox Duo", but did never got an answer.
If I have got it right; in the past the "Zipabox Duo" was tailor made to Clas Ohlson. Both the Zipabox and 433MHz hardware were then in one shell. But now the 433MHz module seems to be loose with common Zipabox.
So: is the module now the same in all 433 MHz packages, or is the one Clas Ohlson sells still tailored? Clas Ohlson tells the module supports "System Nexan and Cotech Smart Home" devices, and those are not mentioned on Zipato site.
http://www.clasohlson.com/fi/Zipato-Zipabox-Duo/36-5595
(Edit: Frequency corrected)
Hey Olli,
The Zipabox duo has the exact same model and device support as the external 433 module on the standard Zipabox. In other words, Nexa and Cotech both work on the external module as well :)
Cheers!
V
Sorry - it is the normal 433 Mhz Modul. Not 933 Mhz.
Oh.. sorry, my bad. Of course both are 433MHz, a silly typo. I'll edit :)
Hey Olli,
Cheers!
V
:) Thanks! :)
