ZXT 120 heating
Emmanuel Papageorgiou shared this question 9 years ago
Hello..
I have a question about my zxt 120 IR ext.
It used to work ok for a couple of months. after an update it started not to work well because it sent an command for every a few seconds or after it saw a diference in the temperature.. After many tries to fix it i master reseted everything to do everything from the begining.
Now it works but.. i can send the OFF, Cooling and Auto Command , i can change the cooling setting temperature but the heating never works.. i can see that the ZXT never gets the command ,Any the led in it doesnt flash.
I've deleted the virtual thermostat created new, i've reseted the ZXT to factory defaults, change run now/until netx.. nothing..
its only the Heating command it never receives to turn on the heating nor the temperature.
Any suggestions?
Emmanuel,
I have seen a few issues in the community (and experienced some others) which I think are due descriptor changes on newer firmwares, I would suggest you to open a ticket on Zipato support (https://support.zipato.com/) and include the serial number of your controller.
i opened a ticket. thank you
