LightwaveRF master switch
Darkwing shared this problem 9 years ago
I added the LW101 master wall switch, but it looks like it is not really working as I hoped.
It gets added per below screen shot:
5c9249fcffa9a1b0a10e41d32709dd40
The device itself has 6 buttons. And it looks like 6 get added............. but what is fake end point? This doesn't show in the rules, so 5 buttons left. Then the one labeled On/Off button 1 does't seem to be doing anything..... I figured out the other buttons as per below:
613ff7448e673cc66f233847c63b818a
So the blue ones are Toggle button 1 to 4, so I am missing Toggle button 5, the big button top left....? As for the small button bottom left, this should be an all off, I guess this is the one labeled On/Off button 1, but it doesn't seem to do anything.
Any help would be appreciated.
How you add LW101 ? When I tried response is " network not availble" Thanks
LightwaveRF is hit ans miss, even if it is supported it sometimes doesn't work. I moved to a different solution.
