pushbullet
Darkwing shared this problem 9 years ago
In Progress
does the HTTP request rule no longer work? I had it set up so a POST was made to pushbullet, but it no longer works...........
any ideas whether this is pushbullet issue or Zipato issue...?
Replies (6)
I had issues with http request when using beta firmware (1.2.10). After going back to official (1.1.38) my http request started working again.
thanks.
Dear All,
We will do our best to resolve this issue as soon as possible and we will keep you informed about the progress.
The only method "GET" from "HTTP request" does not work properly. If you are using "POST" and "PUT" there should be no issues.
Pero Zovkic
As Pero stated, I use POST and PUT and it is working with Phillips Hue and Zipatile/Zipabox...
Great! Changed from GET to POST and now working again.
Thanx!
Confirmed, my http requests did not work anymore after moving to 1.2.15c. Changing all get to post made them all work again. Thanks the hint in this topic. It costed me some headache to find out😀
