Coco AMST-606 Door/Window 433 MHz sensor doesn´t work with 1.2.22
I opened a ticket because both of my sensors were frozen in their state after updating to 1.2.22. Support told me, that they didn´t change anything with 433 MHz and so I feared both sensors might have died at the same time.
I then found out, that one can go back to the previous firmware version of zipabox (1.1.38 IIRC) and both sensors were working again. I repeated this procedure twice and could reproduce those results.
So I´m quite sure, that there is (at least in my case) an issue with 1.2.22 and 433MHz and would like those, who also have the AMST-606 to check this out, too.
Any help is appreciated, even though I already ordered two new z-wave sensors because I am tired of false data due to range problems and the missing feedback of 433 MHz sensors.
Best regards
Klaus
Hello Klaus,
issue is solved as described in your ticket.
Hello Klaus,
