State of device instead of V1 alarm in Android App
Klaus G shared this question 9 years ago
I just added a new device (greenwave socket switch) and it shows me the alarm state in the android app instead of the state. I already changed that for all the other devices so that I see the state (on/off) which is more important, but I can´t find how I did it ;-(( Any ideas? I only remember, that it was quite easy ;-((
Klaus
Hello Klaus,
just rejoin the specific device(s), it should be fixed. If not, then, please, submit a ticket via https://support.zipato.com/
I don´t think that would help. I´m pretty sure all my greenwave sockets started with the Alarm in the android app. I can toggle alarm type, consumption, state and so on but it always switches back to Alarm Type 1. There was some trick to set the state as the default screen in the android app.
Go to the bottom on the device in device manager. Select the setting of the device, which you want to see as first and thick "master".
Thank you Attila, that did the trick. Sometimes I find it confusing with all those groups and options in the devicemanager.
