neo coolcam motion sensor - no option 10
Dimitri Van Hove shared this question 9 years ago
I have the neo coolcam motion sensor connected in the zipatile.
motion and light sensor works. but i have no option 10 under advanced to swtih off the led
How can i view option 10 or switch off the led via zipato ? thanks
Need to add it manually. Click on the add new, type the text to the long field description so you know what the command is.
Then 1st small field is the parameter number (in your case 10)
2nd field is the byte size (you will find this in the manual of the sensor)
3rd field is the value of the parameter. When you move to this field, below you will see new options
send - sending the parameter
receive - receiving the parameter
cancel - no need to describe further
it should work. Give it a try
One question: does the PIR sensor also monitor the light level? I thought it is only motion sensor only.
OK, i have the option and the correct value's , but when i try to send or retrieve i get the message: Please wake up your device. HOw do i wake up the device ?
Yes , its also a lux sensor.
Well, read the manual how to wake up? If there is no specific way to wake up then start the inclusion.
It just stopt blinking .... :-)
