Greenwave power node NS310-F
Klaus G shared this question 9 years ago
Just a short question: Does anyone know, how to set the parameter 3 on those wall switches? Is it just the same as for parameter 1? Im unsecure about the size and don´t dare to change anything on my running system (no problems for weeks, thanks to the Zipato-team!)
I just want to make sure that my six wall plug switches remain in their last state after a power black out. Any help is appreciated.
Klaus
/b11cdd6324ea4c8871b1bdc19e362d0b
maybe you will found something at this adress
I have the 210 and i think it is the same
https://www.domoticz.com/forum/viewtopic.php?t=9372
Change the value from 255 to 1. When you enter the value field you will have options to send and receive the parameter. After changed to 1, hit send. Once sent successfully, hit receive to confirm it is saved.
When complete, hit save on the top and then synch.
Done.
