Does anybody have a Modbus device working and how did you do it?
David Pritchard shared this question 9 years ago
What it says in the question.
If you have a Modbus device working on Zipato, how did you get it working, what obstacles did you come across, and what assistance did you get from Zipato? How did you/they debug it?
Replies (8)
Cant help here, sorry Dav. But also am very interested in finding out.
I originally asked for CoolmasterNet to be supported. I thought it would have been done over IP as most other companies have done, but apparently Zipato supported it over ModBus. I know nothing of Modbus and dont know anyone who does. Not to mention never saw a tutorial on this or any instructions whatsoever. Useless integration.
I've been told "Remote support for Modbus is not possible any more." I get the sense that they're abandoning this protocol, probably under the pressure of too many commitments. I was told to send my Modbus adapters to them by mail. Really.
From 2015:
http://www.cepro.com/article/zipatos_modular_home_automation_system_the_best_smart_home_platform
"According to Popovic, the supported systems are:
- MODBUS..."
About CoolMasterNet. You don't need to know anything about Modbus. To Integrate CoolMasterNet with Zipabox/Zipatile you should do the following.
Telnet to the CoolMasterNet, type "modbus IP enable".
Restart the CoolMasterNet.
Telnet to the CoolMasterNet again, type "va auto".
Go to the "add new device" wizard, select Modbus.
When the Modbus network is created, go again to "add new device" wizard, select Modbus and enter these parameters:
Type: <whatever>
IP address. <the device's IP address>
port: 502
Address Number: <the output of "va auto" command - 1>
Select "Next" and that is it.
thanks, I think. What is Telnet? From what I can see it is a software server that will communicate between the CoolmastNet and the Modbus protocol Zipatile. Or is it? Do you have video of this integration example?
Really would like to see this working.
Does it add to the virtual thermostat? Can you control fan speed via the virtual thermostat?
Telnet is, let's say, a connection type between your PC and CoolMaster. You can download and use a tool called "putty" for that. The support should probably make a video of the integration. You should be able to use it with virtual thermostat. I am not sure if it is enabled to control fan speed through virtual thermostat yet.
great, I just found out this only works for the expensive CoolmasterNet, not CooLinkNet. So in order to allow control via Zipato of a single HVAC system (CooLinkNet), I need to pay thousands for a controller that can control up to 32 units (CoolMAsterNet). http://coolautomation.com/lib/doc/manual/Modbus-guidelines.pdf
Just gets better and better.
We support Modbus as a protocol, but each device has to be supported separatly by us.
Remote support is not possible any more and it is a normal procedure here that users sometimes send their devices to us to support them
Previously I was able to add my (supported) Brink devices on the ModBus screen. Now, only one relay device appears, and nothing else. What's going on?
If you have any problems with your Modbus devices send me your box SN at zcerovski@3plus.hr and I will check what is wrong. We are in the middle of some Modbus implementation changes and there might be some issues with backward compatibilty, but those will be resolved as soon as reported
I opened a ticket. Is that enough?
Yes, it should be enough
