Reliability of Rules
Daniel Stein shared this problem 9 years ago
The Zipabox was working for a couple of monts without any problem. The rules were executed accordingly. After this time, the rules stopped working suddenly. Logging in into the Portal I've seen that there was an update, which I loaded. After that I could not log in until a couple of retries. Finally I made it work again. The rules were working and again stopped working suddenly. Another Log in in the Control Center and I've found out, that there was another update. Same situation again.
Seems, that with every Update available, the Zipabox stops running rules... Unnecessary to say, that this behaviour is extremely bad, as automation won't happen anymore.
Please be aware, that there could be very important monitoring and/or control of IoT's which then fail due to possible updates.
Cheers
Daniel
