firmware 1.2.29m
Serge Kouthon shared this problem 9 years ago
Hi just upgrade to the current firmware version.
I also removed my philips hue bridge (version 2) along with the bulb configuration in order to perform a fresh installation. Unfortunately :
1. I cannot add the Philips Hue Bridge anymore
2. Although I keep removing the light from the IP menu they keep popimg out in the control center
3. On the Zipatile when I try accessing the control setting menu the App crashes.(Meaning I cannot set my connection type to default as requested).
somteimes even if the zipatile fails to include my philps hue bridge, it end up including it, it also add several instance of the same philips hue bulb.
Can anybody help me ? please !
Hello Serge,
There should be no issues with the HUE on this firmware version.
Please raise a ticket @ Zipato support so we could help you out and inspect your case.
V
Anyone having the same issue while updating from 1.2.28m to 2.2.29m?
"Error-25: The new package has an older version code than the currently installed package"
Really Zipato???
M
same
