Rule & Time what to use
Pablo shared this question 9 years ago
I want a device to switch ON and after some time (hours maybe) OFF every day twice, at certain time. For this I have a virtual switch that enables or disables this automatic functionality.
I find two option on the rules:
OPTION 1 - USING SCHEDULE
For this I create 2 rules: 1 for switching ON during at the start time of both periods, the other one for switching off at the end of both periods. The WHEN condition is the schedule 1 OR schedule 2 and on the next IF I check if the automatic trigger is set. This is how it looks like:
7a3055837525ec33ca8aed2527bbd0f1
OPTION 2 - USING TIME BETEEN
ForthisI need only one rule where I define the period while it should be switch ON. On the WHEN condition, I check if the automatic trigger is ON. And afterwards I have an IF with the TIME BETWEEN condition. This is how it could look like:
8c232ded25a3cab61fd6b3c895c8deda
My question is: are they both correct? I've been not able yet to test them completly.
Thanks all!
Rule 2 will never work. It will trigger when you switch on the automatic trigger but not later 9only at switch state change to ON.
Rule 1 can work, however we always recommend using only 1 scheduler in the when and not 2. So you should have 2 rules, 1 for On and 1 for OFF.
Thank you Attila!! For the moment looks like the 2 SCHEDULES withe OR are working for me! And the TIME BETWEEN not, as you explain. Thanks!
