ZWNTUT and wakeup of battery devices
Vineet Bhojnagarwala shared this question 9 years ago
I'm trying to run ZWNTUT, everything works, but it gets stuck on waiting for battery devices to wake up, i've a quad sensor and a keyfob. How do I wake these devices up ?
- I tried pressing everykey on the keyfob, does not work for me.
thanks.
Hooking it to power did not help.
But figured out how to do it, press 2nd buttoin (top right) thrice while press & hold the center button.
Vineet,
Battery operated devices need to be waken up manually or you have to wait until the next scheduled "wake up" time (you can see the wake up time in each device's configuration). See each sensor manual to find out how to wake them up, usually three clicks do the trick but it can vary depending of the sensor/brand.
Best Regards.
Thanks for the pointer Alberto, I found the below in the manual, need to check up:
WAKE UP NOTIFICATIONWhen device is charging, it will send Wake Up Notification tocontroller minutely.
You need to read the manual for all these battery operated devices as everyone of them has different wakeup procedure.
