Support of WiFi sensors?
TorM shared this question 9 years ago
does the Zipato box support the WiFi sensors? Like any of these water sensors:
D-Link DCH-S160
Grohe Sense 22505
you can support it though via IFTTT, or if it has a http or api you can view, you can create your own virtual sensor and have the wifi sensor trigger it this way.
Zipato does not support WiFi sensors, although other protocols like Zwave, Zigbee, 433, are supported.
More you can find on https://www.zipato.com/how-it-works/compatibility
ps though, i would just get a z-wave water sensor. It will last longer on batteries(if you use a battery version), and wont use as much power to operate, also less likely to have interference from other sources and will have added range when combined with a power z-wave device (wifi doesn't mesh) and will communicate directly with your Zipato Controller, not via a 3rd party or router.
