Everspring wall plug AN-1812 is not indicationg Voltage anymore
Lukas Berger shared this problem 9 years ago
Hi!
I got 3 Everspring wall plug AN-1812, none of them indicate voltage anymore.
One of them indicated 0 V, so I removed it from the web interface, resetted it and included it again.
No did it appear a dash before voltage in the web interface and only a V in the Android app.
First did I thought that it was only that plug that wasn't working, then I noticed that the voltage had freezed on the other two devices. One of them indicated 227.96 V and the other 231,47 V. They were both in the same room connected to the same fuse, but different outlets. I switch them with each outher, but they were both stuck on the same value.
I did then remove them from the web interface, resetted them and included them again. Ended up with the same result as the first one, a dash before V on both.
I've tested the official FW 1.2.29, beta FW 1.2.33, 1.2.36, 1.2.37 and even rolled back to 1.1.38.
For the record, did I include them in close range of the controller.
As they all three indicated voltage when I bought them, but no longer, do I think it is a FW error in the Zipabox.
