Setting thermostats
Finn shared this question 8 years ago
I have 4 Danfoss thermostats. 2 of them set up to "Program" so turn on and off daily. The two other is mostly off the time in permanent away or night mode.
When I go away for holiday/weekends I have made a rule that sets all 4 to Away mode so I'm sure there is minimum heat in house (OnOff switch).
When I get back I manually go in for each thermostat and setting its mode. Is there a way to switch all 4 back to the mode it was before I get away?
Example:
Before holliday:
Thermostat 1 = Program mode
Thermostat 2 = Program mode
Thermostat 3 = Night mode
Thermostat 4 = Away mode
Going to holliday setting switch (Rule) "Away ON":
Thermostat 1 = Away mode
Thermostat 2 = Away mode
Thermostat 3 = Away mode
Would like to setting switch (Rule) "Away OFF":
Normaly I do this manually for each thermostat....
