Dual hysteresis on thermostat ?
MaLi shared this idea 8 years ago
I've started to use Zipatile as my thermostat and I'd like to request a feature where you have two settings for the hysteresis, one for on, and one for off.
My heating system is rather sluggish in it's operation and takes a lot of effort to get going, so I rather run it less often and longer, so with that I can accept a 2-3 degree temperature drop before things kick in. But currently that means that setting the hysteresis to 2 degrees means that I also have to live with two degrees higher...
Yes, I could obviously set the hysteresis to 1 degree and set the temperature to 1 degree lower than where I want it and achieve the same thing, but technology is wonderful so while this works as a workaround short term, I'd still like to request that the feature is implemented.
Many Thanks !
// M
