vanne eurotronic
Hello. Is this valve compatible with Zipatile? Thank you.
Yes, this valve is Z-wave plus certified so it is compatible.
Ok thank you.
Ok thank you.
I have 4 Eurotronic valves and 1 Danfoss. Not this model, but I not longer trust in this brand.
Too much battery consumption and to many troubles and lot of disconnections. I have only one which seems working good enough to keep it on line.
Pay more and buy Danfoss, and you will be happier!
salut . J ai aussi essayé des vannes comet qui ne fonctionnent pas correctement . Les danfoss lc13 sont plus ou moins correctes mais l affichage et les boutons ne sont pas pratiques . Merci pour ton retour .
