Heiman HS1DS-Z Door Sensor state not tracking correctly
Paul Pankhurst shared this problem 8 years ago
The Heiman door sensor shows initially as OPEN when the sensor is opened, but immediately returns to CLOSED approx 3 seconds later, even though the sensor is still open.
The state is correctly tracked in the Notifications->ACCESS_CONTROL attribute as Window Open / Window Closed
I have the same problem. A friend that have fibaro hc2 has been able to associate the group 4 with the sensor and it works fine but I did not get it on my zipato. Any help?
I have the same problem, have you found a solution?
I have two of these devices, identical configuration, identical firmware, one works as expected. The other resets to closed after a few seconds
