Zipatile
I'm considering purchasing a Zipatile. Will I be able to migrate all devices and rules from my Zipabox or do I have to redo everything manually?
Unfortunately, you can't just migrate devices from Zipabox to Zipatile, but you can continue using Zipabox in cluster with Zipatile. However, I would still suggest migrating everything to Zipatile as it is generally stronger device.
"stronger device" as in more capable, more features... or stronger as in stronger / more powerful Z-Wave signal ?
While I do agree that it is a more feature rich device, my Zipatile is not even close in signal strength to my ZipaBox and much more "picky" when setting up devices so I ended up using my Zipabox for the majority of the devices (31 of 33) even though it is further away from the endpoint in many cases.
I'm expecting my Zipatile delivered today but already have a Zipabox with 56 devices. I really don't want to go through the hassle of transferring all 56 devices. Is it a big problem if I don't?
