Issue - Qubino ZMNHIA1 Flush On/Off Thermostat
Irmantas shared this question 8 years ago
I'm using "Qubino ZMNHIA1 Flush On/Off Thermostat" - named "WC 2a thermostat" for Water Underfloor Heating. For switching valve is used - "Fibaro in wall double switch 2 x 1.5kW" named "Sw-WC 2a RL1".
I've created Virtual thermostat Pro:
- Heating Outputs: "Sw-WC 2a RL1
- Heating Input: "WC 2a thermostat\WC 2a In-wall thermostat"
- Thermometers: "WC 2a thermostat\WC 2a In-wall thermostat"
The problem is - that Virtual thermostats goes to Program=Until Next and Mode=OFF after couple of minute when I set it to RUN and AUTO.
Current temperature = 21,8; Week Program is set - Heat 24. So it must use week scheduler ad switch to HEATING.
Could you tell me why it goes to UNTIL NEXT and OFF? Could you point me - how to debug my setup?
P.S. There is no issues with Heatit Tehrmostats - with same setup
P.P.S. Qubino ZMNHIA1 Flush On/Off Thermostat is the product recognized by zipato, but it is NeticHome Thermostat
Regards,
Irmantas
