Nexa LMLR-710 Ringtone wall plug, does it work?
i try to find out how i can make it sound from controler. Could some one confirm that its working?
regards
Hi.
Yes it works.
I've added it as Chacon LMLR-710 (but it now seems to be able to add as Nexa LMLR-710 as well)
But it will be as generic plugin. But you can change this to Siren.
It will however only chime once when you turn it on, and then you would need to turn it off again to be able to turn it on.
It will only be included as one device, but the LMLR-710 can hold multiple id's to different sounds. So I included it 5 times and matched it to different chimes.
Hi.
Yes it works.
Thank you Stefan, it works now. This is wery useful!
