Aeon labs multisensor 6
Kaupo shared this question 8 years ago
Hello
How do I configure/add aeon multisensor 6 correctly?
It shows 0 LUX and 0 UV while in the room and it shows motion when there isn't any and the other way around also.
Seems like it gets updates like once in 30min or some other unreasonable time.
Hi Kaupo
i must say Zwave and ZipaTOY have this issues every time
firmware by firmware it goes to be worth
if u want to use zwave in home automation please note that theres no stability
I see that the problem was discovered years ago, but isn't it fixed somehow already?
Kaupo, check the manual of the sensor. I have this same on the ceiling with the adapter and it works pretty well. If I remember properly, some offsets and sensitivity was available.
Could you please send me a picture of the configurations you have with this device?
I cannot find a manual that says anything about zipatile/zipato.
Hello Kaupo,
On your my.zipato.com, go to Device Manager > ZWave > Look for your Aeon > click on config (gear icon) > configuration tab. There you have plenty of calibration parameters.
I suggest you always read the manual of the device (in this case Aeon multisensor) because normally there are plenty of additional features. Check it here https://aeotec.freshdesk.com/support/solutions/articles/6000057073-multisensor-6-user-guide- on the bottom of the page you have more detailed features.
Hope this helps.
