Don´t get a Pin Code installed for Alarm Partition for other users
Bernd shared this question 8 years ago
I´ve read up and down in the Knowledge Base and found the Tutorial to
Administrate member security privilege
I followed step by step and during the implementation process everything looked fine. But at the end the codes are not working. The only working one is mine.
Where is my mistake??
Bernd
Hello Bernd,
this should be of some help: https://www.youtube.com/watch?v=DwaNWqtzqek
Stefan
0
Hello Bernd,
Stefan
Stefan,
sorry but it doesn´t work. Are there any specific things with the intruder alarm? I have three users, myself as the master my wife and one of our children as members. I would like to see who armed / disarmed and therefore would like to have different Pin Codes.
I went to the user section and put in my Pincode and then twice the new Pincode and saved and synced. And afterwards in the intruder alarm section I gave them the right to see, arm, disarm and bypass. save and sync. But the Pincodes don´t work.
By the way I have a similar problem with two keyfobs which cannot be implemented in the intruder alarm as devices for arming / disarming. The installed Mini Keypad works - with two different tags. But when I try to add another device the keyfobs are shown, I can choose which click should start which action I save and update and the keyfob is gone - the fields for the second device are empty again. I helped me so far with a rule for each keyfob but in my opinion it should work directly without a rule.
