Static IP and Users Rights
Gabriele shared this question 8 years ago
I am not able to setup the static IP on my zipabox. How can I do this. Even if i restart the box the address is provided by DHCP. I can't setup a static mapping MAC/IP on the router. This function is not available. I have to do this on the box.
I've also created users but I can't save the Role "tenant plus" I got a error message "Falied to save user data"
Thanks !
0
Hello Gabriele,
regarding the static IP, you will have to set one on your router, please consider the manual of it in order to set it correctly.
The tenant plus option makes sense on the ZipaTile only, since it basically is the tenant role with the rights of adding widgets on the ZipaTile home screen. Did you try the tenant (only) option?
Stefan
0
Thanks Stefan,
Regarding "tenant" my scope is to add administrative rights to another user.
Is it possible ?
0
Hello Gabriele,
yes, this is possible, yet the tenant rights are limited rights, you can add a user as a member to your controller in order to gain full access to it despite being a member. I hope this helps.
Stefan
