Can the Amazon Echo Show/Spot be controlled from Zipato?
David Pritchard shared this question 8 years ago
I know the Amazon Echo devices can be used with skills to control smart devices, either directly or via a home automation controller like the Zipabox, but does it work the other way around? Can you send a command (apart from a voice command, obviously!) to dim or turn off the screen of an Amazon Echo Show or Spot from the Zipabox?
