Adding devices under 1.0.14
            Under the latest beta firmware I can't seem to add any device.
Sonos is stuck on Discovery in progress
Somfy RTS is stuck in adding devices
Danfoss living connect is stuck on joining deviceReset to defaults didn't change anything.
Nothing seems to work with the zipato box, right at the moment I'll probably just return it to amazon.
Obviously there is some problem with your controller which is causing all these issues. These are all related to pairing process. Please contact support@zipato.com and we will help you from there....
I have the same problem after update. Box just stays in "starting device exclusion proces"-screen
I can't add Nexa WTE 2 switch. Could this bee related?
And even tho I have deleted the Nexa switch the rule works? The rule even say unknown of the device?
just upgrade to 1.0.15
Done that!
Done that!
