aeotec multi sensor time interval with battery
Emmanuel Papageorgiou shared this question 8 years ago
Hello
I have a Aeotec and a Fibaro multi Sensor and I have a question
I want to use the Aeotec with batteries but I can’t change the time interval for temperature reporting
Be default it sends every hour. I want to change it to 10 or 15 minutes but I can’t make it work
I changed the G1 interval and I have inserted a custom configuration (111 4 600 ) but it still sends every hour
The fibaro works fine and it sends every 10 minutes
Any ideas?
(if I use it with usb it’s ok)
Thank you
Hi, if you cannot changed it, it means that is hard-coded by Aeotec. You should read manual of device, and eventually contact Aeotec support.
