Cannot add Heatit zwave thermostat
I am trying to add a Heat it zwave plus thermostat without luck: the device can be included, is recognized. However the device 'times out' during the configuration phase! Please help.
I guess raise a ticket with support.
did you try to reboot the box and try again?
regards Helle
regards Helle
https://youtu.be/tvyi6zFkoCE
As it is supported: https://community.zipato.com/topic/heatit-thermostat-for-electric-floor-heating-does-zipato-support-it
Raise a ticket with http://support.zipato.com/
I recently installed 2 HeatIT thermostats. I had to give it a couple of tries connecting and configuring, but after inclusion/syncronization it works fine.
Really a nice device for my Danfoss/devireg electric floorheatings in kitchen and bathrooms.
Thanks Troels, good to know it does work.
I have tried it more then 20 times without luck. I have to reboot my box between each try.
Everything works up to the last step to configure the device.
Very frustrating.. I consider myself to be 'tech savvy' but this is definately not something for the regular consumer market yet...
Solved!! Attempt 22 worked!
I have the same problem, what did you do different at attempt 22?
