Coco AMST-606 Door/Window 433 MHz sensor doesn´t work with 1.2.22
Klaus G shared this problem 9 years ago
I opened a ticket because both of my sensors were frozen in their state after updating to 1.2.22. Support told me, that they didn´t change anything with 433 MHz and so I feared both sensors might have died at the same time.
I then found out, that one can go back to the previous firmware version of zipabox (1.1.38 IIRC) and both sensors were working again. I repeated this procedure twice and could reproduce those results.
So I´m quite sure, that there is (at least in my case) an issue with 1.2.22 and 433MHz and would like those, who also have the AMST-606 to check this out, too.
Any help is appreciated, even though I already ordered two new z-wave sensors because I am tired of false data due to range problems and the missing feedback of 433 MHz sensors.
Best regards
Klaus
Hello Klaus,
issue is solved as described in your ticket.
