Combine meters from same device
Is there a way to combine two meters from one device into a group?
You need to activate the upper device in the device manager as visible device.
It already is. It's a Fibaro RGBW Controller and the device above the power meters is the RGBW device itself.
Okay, with this hierarchy you can find the two meters below the RGBW controller. There is no other possibility, as far as I know.
Ok, thanks DUC750.
Ok, thanks DUC750.
